Ohnoto Posted April 13, 2011 Share Posted April 13, 2011 Below is my LISP code. What it currently does is adjust the date field on our drawings. I am trying to modify it where it will prompt for today's date, or then it can be adjusted manually. The problem is that when prompted for today's date and hitting enter, the value isn't stored and comes out as "----", but when it is typed out, it works fine. (defun c:AD () (vl-load-com) ;;; Do not forget to add (Today) (setq str (getstring t (strcat "\nDate to be Placed - <" TodayDate ">"))) (if (null str) (setq str TodayDate)) (_dwgru-dwgprops-set-custom-prop "PlotDate" str nil) (princ "\n ----------------------------------------------") (princ (strcat "\n --------- Adjust Date - Version " ADTVerNum " ---------")) (princ (strcat "\n ---------------- Date: " str " --------------")) (princ "\n ----------------------------------------------") (princ) ) If anyone needs more of the code, I will post it up, but since this is dealing with the if statement not sure if it's needed. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted April 13, 2011 Share Posted April 13, 2011 This is an example of how to save a value to argument ... (setq wid (if wid width 100.0 ) ) (if (progn (initget 6) (setq width (cond ((getdist (strcat "\n Width of Rectangle : <" (rtos wid 2 2) ">:" ) ) ) (T wid) ) ) ) (setq wid width) ) TharwaT Quote Link to comment Share on other sites More sharing options...
BlackBox Posted April 13, 2011 Share Posted April 13, 2011 This will feed the current date as a string to a LISP function: (menucmd "M=$(edtime,$(getvar,date),YYYY-MO-DD)") ... And this is DIESEL for an attribute field: %<\AcDiesel $(edtime, 0,M"/"DD"/"YYYY H:MM:SS AM/PM)>% Hope this helps! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 13, 2011 Share Posted April 13, 2011 Consider this example: (defun c:AD ( / str today ) (setq str (cond ( (eq "" (setq str (getstring t (strcat "\nDate to be Placed <" (setq today (menucmd "m=$(edtime,$(getvar,DATE),DD.MO.YYYY)")) ">: " ) ) ) ) today ) ( str ) ) ) (princ str) (princ) ) Quote Link to comment Share on other sites More sharing options...
Ohnoto Posted April 13, 2011 Author Share Posted April 13, 2011 I'm not looking to automatically do today's date in a field. I do know how to do that. The reason being is that when we send off prints, and then get them back we use the date to verify the drawing in that it wasn't a revision, as we only update the dates on prints with revisions, and if we had the date automatically update we couldn't do that. Not having these dates auto update is important since many times our dates have to coincide with permitting jurisdictions as well. So currently our date's are embedded into a block, and I came up with a LISP to update a custom field to allow for updating the date without needing to go into the block editor. And I'm just having an issue with that if statement. Quote Link to comment Share on other sites More sharing options...
Ohnoto Posted April 13, 2011 Author Share Posted April 13, 2011 Thanks Lee. I was able to put that in before the adjusting field and it worked! Quote Link to comment Share on other sites More sharing options...
BlackBox Posted April 13, 2011 Share Posted April 13, 2011 I'm not looking to automatically do today's date in a field. I do know how to do that. The reason being is that when we send off prints, and then get them back we use the date to verify the drawing in that it wasn't a revision, as we only update the dates on prints with revisions, and if we had the date automatically update we couldn't do that. Not having these dates auto update is important since many times our dates have to coincide with permitting jurisdictions as well. So currently our date's are embedded into a block, and I came up with a LISP to update a custom field to allow for updating the date without needing to go into the block editor. And I'm just having an issue with that if statement. Dude, I never suggested that you to hard code either the LISP, or DIESEL expressions to automatically revise your block. We use several expressions in what we call a 'plot stamp'... when the drawing was last saved, and by whom, when the drawing was last printed, and by whom, and the drawing's file path, and layout name. Each updates only when the applicable task is executed. As Lee showed you in his posted example, the menucmd statement I provided above works quite nicely. Personally, I use a toolbox function: (defun i:Date () (menucmd "M=$(edtime,$(getvar,date),YYYY-MO-DD)")) ... for tasks like this: (defun c:AD (/ str today) (setq str (cond ((eq "" (setq str (getstring t (strcat "\nDate to be Placed <" (setq today [b][color=red]([/color][/b][color=blue]i:Date[/color][b][color=red])[/color][/b]) ">: ")))) today) (str))) (princ str) (princ)) ... But that's becasue I'm lazy, and don't like to re-type everything. Quote Link to comment Share on other sites More sharing options...
Ohnoto Posted April 13, 2011 Author Share Posted April 13, 2011 I apologize, I wasn't being rude or trying to dismiss you. I just read through your posting too quickly and when I saw the diesel code thought that it was for auto-updating date and time, and in my error further explained my working procedure. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted April 13, 2011 Share Posted April 13, 2011 I apologize, I wasn't being rude or trying to dismiss you. I just read through your posting too quickly and when I saw the diesel code thought that it was for auto-updating date and time, and in my error further explained my working procedure. No worries, Ohnoto. Quote Link to comment Share on other sites More sharing options...
