pmxcad Posted April 13, 2011 Posted April 13, 2011 Hello, Question: I have group with six blocks, how do i simply remove a a block from the group by selecting a block?. Second question: is it possible to copy attribute data from a selected block to the attributes from the blocks in a group with the same attribute TAG ?. Can this done by LISP Thanks Quote
JohnM Posted April 13, 2011 Posted April 13, 2011 use the group command, find the group, then use remove to remove objects from the group for the second question: there are tons of post here about thet, just search this site and you will find some code to to this Quote
SOliver Posted April 13, 2011 Posted April 13, 2011 Depending on the action you're intending on carrying out the acad select objects method allows you to remove entities from the current selection by entering "r" into the console. Quote
