mvrcad Posted April 14, 2011 Posted April 14, 2011 HI all I regularly use the text \xmin and \xref and \xtyp to add text to underline of dimensions to say MIN, REF and Typical however to do this i need to go to properties and type in this text in the dimension text overide panel. could AutoCAD incorporate this into their next release if there isnt allready a solution? cheers Quote
ReMark Posted April 14, 2011 Posted April 14, 2011 Why not add the text below the line at the time you are creating the dimension? It would negate having to go to Properties and use the text override option. The AutoCAD Users Group International maintains a wish-list for future releases of AutoCAD. Suggestions are solicited and voted on each year. Take advantage of the opportunity to add your suggestions by visiting the AUGI website. Quote
