I am using Autocad 2000. I know, I am like an old dog who gets comfortable by the fireplace, and is happy with what I have.
Please someone tell me where the toggle is to set the dimensioning for metric dimensions. I have seen it in a couple of places and after I set it for millimeters, for some reason it still dimensions in English measurements. It's more than clear that I don't know what I am doing. If someone could help me, I'd appreciate it.
thank you,
gotchy
You have used the UNITS command?
Are you also using a metric template?
'English measurements' - don't the British use the Metric system though?
Format -> Dimension Style -> Select the dimension style of your dimensions and then change the units in the Primary (and if you want, Alternate) Units tabs
