Arizona Posted April 19, 2011 Posted April 19, 2011 Looking for a routine that will place a point node on a polyline at a specified distance (along the winding polyline) from a specified point on the same polyline. I'm sure sombody has already written a routine for this. Thanks for any help I can get, Jeff Quote
alanjt Posted April 19, 2011 Posted April 19, 2011 Quick modification to one I use (I like to have it place a circle)... (defun c:MAC (/ *error* pt ent dap dist pad) ;; Measure Along Curve (place circle(s) at specified distance(s) ;; Alan J. Thompson, 10.28.10 (vl-load-com) (defun *error* (msg) (redraw) (and ent (redraw ent 4)) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,"))) (princ (strcat "\nError: " msg)) ) ) (if (setq pt (getpoint "\nSpecify measure base point on curve: ")) (if (vl-catch-all-error-p (vl-catch-all-apply (function (lambda (/) (vlax-curve-getEndParam (setq ent (ssname (ssget pt) 0))))) ) ) (alert "Point must be on curve!") ((lambda (total 2ten) (redraw ent 3) (while (progn (initget 2) (setq dist (getdist pt (strcat "\n[Total length: " (rtos total) "] [Positive length: " (rtos (- total (setq dap (vlax-curve-getDistAtPoint ent (trans pt 1 0))))) "] [Negative length: " (rtos dap) "]\nSpecify distance along curve to label: " ) ) ) ) (if (setq pad (vlax-curve-getPointAtDist ent (+ dap dist))) (entmakex ;;(list '(0 . "CIRCLE") (cons 10 pad) (cons 40 (fix (* 0.1 (getvar 'viewsize)))) 2ten) (list '(0 . "POINT") (cons 10 pad) 2ten) ) (alert "Point outside of curve limits!") ) ) ) (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent)) (assoc 210 (entget ent)) ) ) ) (*error* nil) (princ) ) Quote
Arizona Posted April 19, 2011 Author Posted April 19, 2011 Sweet! That rocks! It's perfect, exactly what I needed. Thanks so much Alan. Quote
alanjt Posted April 19, 2011 Posted April 19, 2011 Sweet! That rocks! It's perfect, exactly what I needed.Thanks so much Alan. You're very welcome. I find it quite useful myself. Quote
