Hi
At present we have a repetitive process in the office that means we have a guy measuring distances in CAD, copying/typing X,Y,Z distances into an excel sheet where a calc is performed.
I would like / need a LISP routine that will copy X,Y and Z and then when I hit paste in Excel, the data is pasted in 3 seperate cells (either columns or rows, whichever works!).
Has it been done before or would anyone like to have a go, or show me how to do it?
Cheers
Kyle
DataExtraction?
Not applicable - its to measure distances between cad objects, not measuring the lengths of objects. And its not every object in the drawing or even by layer. Distance from/to points have to be selected manually.
Perhaps give something like this a try:
(defun c:L2XL ( / *error* _release p1 p2 r xlapp xlcells ) (vl-load-com)
 ;; © Lee Mac 2011
 (defun *error* ( msg )
   (if (and XLApp (not (vlax-object-released-p XLApp))) (vlax-put-property XLApp 'Visible :vlax-true))
   (mapcar '_release (list XLCells XLApp))
       (princ (strcat "\n** Error: " msg " **")))
 (defun _release ( object )
   (if (and object (not (vlax-object-released-p object)))
     (vlax-release-object object)
 (if (setq XLApp (vlax-get-or-create-object "Excel.Application"))
     (setq XLCells
       (vlax-get-property
         (vlax-get-property
           (vlax-get-property
             (vlax-invoke-method (vlax-get-property XLApp 'Workbooks) 'Add)
             'Sheets
           'Item 1
         'Cells
     (setq r 0)
     (while
       (and
         (setq p1 (getpoint "\nSpecify First Point <Done>: "))
         (setq p2 (getpoint "\nSpecify Next Point <Done>: " p1))
       (vlax-put-property XLCells 'Item (setq r (1+ r)) 1 (rtos (distance p1 p2)))
     (mapcar '_release (list XLCells XLApp)) (gc) (gc)
   (princ "\n--> Could not interface with MSExcel.")
Press Enter when finished picking points.
FYI, you could also cheat (not that there's anything wrong with what you've done) and just write it to a text file (saved as *.XLS), just separating each item with a tab - it'll open perfectly in Excel.
And yet you felt no need to include such relevant information. You could still use _DATAEXTRACTION.
I've done this for .CSV before; I thought it was pretty simple to:
(setq textLines '(("This" "is" "a" "test")
                 ("Just" "another" "example")))
(foreach item  textLines
 (print
   (vl-catch-all-apply
     'strcat
     (mapcar
       (function
         (lambda (x)
           (strcat x ",")
       item)
I've honestly never looked into replacing "," with a tab (and obviously .CSV with .XLS*). :oops:
Edit - Instead, I went the (setq xl (vlax-get-or-create-object "Excel.Application")) route. LoL
Edited by BlackBox
^^ Minor code update ^^
"\t" will do it.
BTW, why are you catching it as an error? If it does throw an error, won't it write that error to the file?
I 'spose you're right... I wrote the code on the fly (as noted by the print)... it's not part of any routines. I only included the write-line for others' use.
Suuuuuure. [ATTACH]27165[/ATTACH]
You really drink from the (lilly) pond a lot! LoL
embarrassed_smiley.gifProbably a bit too much.
 ;; © Lee Mac 2011
     (setq XLCells
       (vlax-get-property
         (vlax-get-property
           (vlax-get-property
             'Sheets
           'Item 1
         'Cells
     (setq r 0)
     (while
       (and
Hi...gave this a try. It seems to give paste only the "distance" as opposed to X, Y, Z?
Also I don't need the code to open an Excel sheet and paste the values, just to hold the values as copied so that I can paste them into an existing Excel sheet.
Apologies, could have been a bit more prescriptive in my original posts...
Again I have found a hero in Lee Mac!! This will save me a ton of time on my projects! Thank You
