simo2006 Posted October 1, 2008 Share Posted October 1, 2008 Hello Dose anyone know how to insert arrow or indicator sign? Thank you:) Quote Link to comment Share on other sites More sharing options...
Dipali Posted October 1, 2008 Share Posted October 1, 2008 use leader command & than change the type of arrow in property window the way you want Quote Link to comment Share on other sites More sharing options...
simo2006 Posted October 1, 2008 Author Share Posted October 1, 2008 Thank you for your replay, the arrow to shows the air of the duct going out or in thank you Quote Link to comment Share on other sites More sharing options...
Metyu Posted October 7, 2008 Share Posted October 7, 2008 useleader command & than change the type of arrow in property window the way you want Hi, I am a new user, editing a dwg. When I use the leader command, the arrowhead and font is tiny compared to the surrounding dwg. Is there any way of changing the arrowhead size? I have also tried creating a dimension and exploding it, but this leaves me with the same problem, which is wanting to be able to easily manipulate the arrow. I have edited another drawing where the arrow is controlled by points at either end, so it is very easy to move the arrow and label around the dwg. Any help appreciated! M. Quote Link to comment Share on other sites More sharing options...
Metyu Posted October 7, 2008 Share Posted October 7, 2008 Found this answer by searching "arrowhead" instead of "arrow"... http://www.cadtutor.net/forum/showthread.php?t=22731 Quote Link to comment Share on other sites More sharing options...
Tankman Posted October 7, 2008 Share Posted October 7, 2008 Like Dipali said, "Use the leader command." Edit the arrow in "modify properties." Quote Link to comment Share on other sites More sharing options...
bhargav1987 Posted April 10, 2010 Share Posted April 10, 2010 Is there any possibility to draw a leader line with only arrow. i think u will see a case if a polyline of only 0.3 length is there then we can't draw leader line showing arrow so any possiblity to do it..to remove the line:roll: Quote Link to comment Share on other sites More sharing options...
kencaz Posted April 10, 2010 Share Posted April 10, 2010 Use a pline with width for your arrow. It's fairly simple and gives you ultimate control. KC Quote Link to comment Share on other sites More sharing options...
bhargav1987 Posted April 10, 2010 Share Posted April 10, 2010 IS there any possibility to link a text kept near polyline so tat changing in text will change color of line........ using vba i am desperate to know if there is any possibility:( Quote Link to comment Share on other sites More sharing options...
