Close... oh so close...
For the value of 77.5725, the stationing would be 0+78, but it put the value of 77+57.
as another example, If the footage was 1058.4878, the stationing would be 10+58, 105687.4578 would be 1056+87.
Oh right - that wasn't so clear from your other posts so I took a wild guess at it, I'll look to revise the code.
  • Replies 27
  • Ohnoto
    13
  • Lee Mac
    12
  • stevesfr
    2
  • alanjt
    1
PERFECTO :-)
Sorry for the confusion on dividing by 100, sometimes the simplest things avoid my mind.
I would like to add in a parameter that if the STA tag is blank, it won't put a value in the STA tag, how would I do that?
I tried this, and it didn't work.
(if (/= "STA" null)
(LM:SetAttributeValue o "STA" (vl-string-subst "+" "." (rtos (/ s 100.) 2 2)))
(if (/= "STA" null)
"STA" is just a string, it will never be nil - you need to get the value associated with the attribute with tag "STA".
Kinda what I thought, which would mean editting your defun code for applying an attribute, at the bottom, right?
Replace:
With:
(vl-some
 (function
   (lambda ( a )
     (and (eq (strcase (vla-get-tagString a)) "STA")
       (or (eq "" (vla-get-textstring a))
           (vla-put-textstring a (vl-string-subst "+" "." (rtos (/ s 100.) 2 2))) t
 (vlax-invoke o 'getattributes)
And remove the 'LM:SetAttributeValue' subfunction, since it is no longer required.
