Batch convert DGN to DWG
Hello,
I'm looking for a batch convert program to go from dgn to dwg; however I cannot afford what I have found online. Any and all help is appreciated.
Thanks,
Phil
Autocad has a read DGN function you could write a script to do multi dwg's no cost. _import
thanks Al, a great idea....
How did you make out with this batching tool?
getfiled (bit 16), vl-directory-files, foreach, mapimport?
(^^ Not sure if that last one works for non-vertical AutoCAD ^^) :unsure:
My batching progarm has only been tested with electrical schematics originally develope on Micro Station.
Are you workin with 3D imports to dwg?
