When upgrading from 2004 to 2009, there must be something I don't understand about the layer manager. In 2004, there were no problems, and 2009 has been very frustrating. Frequently, when opening drawings the layouts are not right, and will not restore. There has to be something different in the applications. Can anyone help?
I fail too see the connection with Layer Manager and "when opening drawings the layouts are not right, and will not restore".
I picture is worth a thousand words (not sure what a .dwg is worth.)
What layout? The Layout tab, how your lines appear in the Model tab or your ACAD screen/toolbar layout?
Either way, how would Layer Manager have any effect?
I'm in agreement with the other posts; we need more information to better help you.
I used Land Desktop 2009 for almost two years (prior to our transition to Civil 3D 2011), and have not experienced this issue to date.
Make sure you've had all software updates and HotFixes (i.e., Raster Design 'Solid Fill', etc.) installed.
Are you turning layers off instead of viewport freezing them to not display layers in viewports? Turning layers on/off and using layer isolate can cause problems.
