How to import google sketchup file into inventor?
Ste1978
 Share
I I have google sketchup pro and have been given an image to try to insert to inventor, so we can add conveyors and hoppers, various other blocks.
I have managed to export the drawing into a Autocad 3D drawing, but from here I can't seem to find a way to get this in inventor.
Can anyone help? I have attached the dwg file, if anyone can make this into a part/assy for inventor then I would be very grateful and intrigues how you did it!
Many thanks,
Stephen
File is 1.4mb so I have uploaded it to this website:-
http://www.filesonic.com/file/937491264/ironbridge3d.zip
The problem you've got here is that Sketchup creates a mesh model and Inventor Creates a solid model. Even if you get the Mesh into Inventor it will appear 'Jagged' - Circles and arcs will look like polygons and faces will be composed of a number of triangles.
Check Out this post for an explanation of the differences:
http://cadsetterout.com/cad-setter-out/resources-choosing-a-3d-package/
You could try exporting to SAT, which Inventor should read.
You could try this download from Sycode:
http://www.sycode.com/products/skp_import_iv/index.htm
(Includes a good graphic that shows what you are going to get)
You would probably be better off re-modelling the part in Inventor.
Inventor will import the dwg, but as indicated, faceted surfaces are of little use in Inventor other than for reference.
I see, although when I try and import my Inventor just locks up, it's obvious something is not right. My method will have to be the other way around, export the inventor parts/blocks to 3ds and then add to sketchup, this will be suffice for this project!
Thanks again guys.
 Share
