Dear all,
I use the commnad "spaceconvert" apply on object is return the error mesage " 1 space not created from invalid profile." Is there any method to solve this problem ?
Thanks !
What software are you using? Your profile says AutoCAD 2004.
I have already updated my profile to AutoCAD Architecture 2011.
Is this in one file or more than one?
My initial guess would be that you have some overlapping lines or other errors in your geometry. If you could post the portion of your file that is creating the error, you may have someone give it a look and solve your problem.
It is only one file and you are correct. The object contain overlapping line inside. But ADT2007 able to convert this object to space but 2011 can't. Do you know is there other method to do that ?
AFAIK by searching around some CAD sites, starting in 2008 spaceconvert would no longer work with overlapping lines, etc. You will just have to clean it up AFAIK or use pre-2008.
Thanks ! But what is pre-2008 ? another software for AutoCAD ?
That means an Architecture Program released prior to Architecture 2008. In other words an OLDER program.
thanks for your suggestion.
