kalai Posted May 12, 2011 Posted May 12, 2011 i am getting error below error: bad argument type: fixnump: 4.0 in select objects when creating a block, what could be wrong? help me. Quote
Tharwat Posted May 12, 2011 Posted May 12, 2011 Post your codes to give us the chance to check them out for you . TharwaT Quote
kalai Posted May 12, 2011 Author Posted May 12, 2011 thanks , i found out anyway ,it is problem with datatype Quote
Lee Mac Posted May 12, 2011 Posted May 12, 2011 FYI: When you see an error of the form: error: bad argument type: <data type> : <value> It means you have supplied a function with data of the wrong type. The data required by the function is noted by the part of the error, hence: 'fixnump' - function requires integer argument 'stringp' - function requires string argument 'numberp' - function requires integer or real argument etc And the part indicates the data that you have attempted to pass to the function which usually gives a good indication of where the code has failed. Lee Quote
pBe Posted May 13, 2011 Posted May 13, 2011 and of course there is this: http://lee-mac.com/debugvlide.html Lee, kudos on your website Quote
