Where can I adjust the space between the lines of text? It is a little too big for me :)
If You are using Mtext you will get this bar there are options for line spacing where i circledmtext.JPG
Score! Thanks. For some reason though the template file does not want to remember the setting for where I really want the line spacing (.85x). It keeps defaulting back to normal and I keep changing it and saving it hoping it can become the standard from the template file. Any reason why the line spacing cannot be saved?
http://forums.augi.com/showthread.php?t=40759
This explans your problem you may need a start up lisp.
I can write this for you but i am busy right now so i will do it later today
there might be an better way i suggest you google the problem
Edited by SunnyTurtle
What i said before was completey wrong
The TSPACETYPE system variable will always default to the value of "1" because it is not saved in the drawing nor is it saved in the Windows Registry. As mentioned previously you might be able to use a lisp command to save the variable.
TSPACETYPE
Controls the type of line spacing used in multiline text. At Least adjusts line spacing based on the tallest characters in a line. Exactly uses the specified line spacing, regardless of individual character sizes.
1 At Least
2 Exactly
