FIFTHTEXAS Posted May 16, 2011 Posted May 16, 2011 hi ai there a way to edit a colour of an x-ref whilst in different drawings, using the same x-ref in each of say 10 drwings, but in a couple of the drawings you would like the x-ref to act in a different way visually, a standard colour grey is used in most of the drawings, but i would like in a couple of the drawings to make the x-ref really light, for use in specific areas, is there a way you can set how your xref looks in each drawings, or can it only perform in one way on all drawings, thanx Quote
Tiger Posted May 16, 2011 Posted May 16, 2011 If you have VISRETAIN set to 1, the changes you make to the Layer Structure of the X-ref is saved with your drawing. Quote
designerstuart Posted May 16, 2011 Posted May 16, 2011 yes open layer menu, select xref in left hand pane, select all in right hand pane (now you have selected all layers from that xref in this drawing) then just change to whatever colour you want. VISRETAIN is useful here - it determines if these colours are saved and is possibly the best way to undo colour changes. Quote
designerstuart Posted May 16, 2011 Posted May 16, 2011 well i'm slower than you tiger, but at least we agree this time! Quote
irneb Posted May 16, 2011 Posted May 16, 2011 This is probably the biggest reason you should draw everything on colour ByLayer. Otherwise there's no way you'll get the colours working as you've stated. BTW, that's also why there's a command SetByLayer (Modify --> Change to ByLayer). Quote
Tiger Posted May 16, 2011 Posted May 16, 2011 This is probably the biggest reason you should draw everything on colour ByLayer. Otherwise there's no way you'll get the colours working as you've stated. BTW, that's also why there's a command SetByLayer (Modify --> Change to ByLayer). Word. ........... Quote
