Mason Dixon Posted May 17, 2011 Share Posted May 17, 2011 I work for a caststone company and we mainly do decorative banding on buildings. To make my drawings, I make a plan view based on architects specs and sweep a profile around that plan view path. I've been using SLICE to break it up into chunks that get the banding and others that will be a door, window, etc. It is really tedious slicing up each line for the 3/8" mortar joints that are required to divide each, roughly, 40 inch wide piece of individual caststone. What I would like to do is make my 3d plan view, put lines in where there is doors/windows, and be able to slice through every one at the same time. Then I would like to be able to select the sections that will be the banding and type a command(guessing custom made?) that will break up the sections into roughly 40 inch pieces that have 3/8" mortar joints in between. Here is a sample drawing I also need to make 'shop drawings' which is a sheet that has a plan view, elevation and section of each piece that I just divided up above, for our mold maker to make the wooden molds for the concrete mix. I guess the same command above would also create an entity in a database for each piece which would allow me to print out a shop drawing ticket for each piece with just a few keystrokes. Sample Shop Ticket Lastly, the building plan drawings get sent out to the mason's in the field. Would be nice if I could type a command and have each piece labeled with something like A1, B4, etc that shows the mason's where each piece goes in the field. Sample Field Use I just heard about LISP commands, would something like that do what I need above? If anyone here thinks this is pretty easy to do, I will gladly paypal anyone who thinks they can help me out in detail here, just PM me your bid price. Thanks Quote Link to comment Share on other sites More sharing options...
designerstuart Posted May 17, 2011 Share Posted May 17, 2011 well i am not a lisp writer, but i believe lisp would certainly help, although i think this would be quite a big job! maybe not impossible. i expect you would have several separate scripts which do each part of what you are trying to achieve. someone who knows about coding will be along soon. Quote Link to comment Share on other sites More sharing options...
designerstuart Posted May 17, 2011 Share Posted May 17, 2011 also, i assume you are more interested in having someone do this coding for you, than learning how to do it yourself? Quote Link to comment Share on other sites More sharing options...
Mason Dixon Posted May 17, 2011 Author Share Posted May 17, 2011 also, i assume you are more interested in having someone do this coding for you, than learning how to do it yourself? Very much so, I just simply don't have the time and my company said they would pay for a custom solution. Please PM me if you want to talk more about this. Thanks. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted May 17, 2011 Share Posted May 17, 2011 (edited) [OffTopic] Huh, good 'ole Eglin AFB... I had the pleasure of staying there during Hurricane Duty for a few weeks (Hurricane Dennis I believe?), operating the Depot site, issuing Travel Maps to Semi drivers, and unloading gear flown in by UH-60 (Black Hawk) (i.e., food, water, tarps, medical supplies, etc.). First we stayed in a building by the airfield with holes in the roof (no major damage to the super-structure), then we moved into gigantic tents (+/-75 occupants ea) with wall sized mobile AC units. LoL [/OffTopic] Edited May 17, 2011 by BlackBox Typo Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 18, 2011 Share Posted May 18, 2011 The coding is not very hard for the sizing part its just a case of taking a length and working out how many times the block length plus mortar joint fits into a length and then saving remainder. I have done exactly this for a Client it was prefab panels we ended up with a parts list 42x40 3x26 1x12 2x4 etc The dims could be added as you go. Unfortunately I do not have the code. The parts drawing would be easy also as you make a list somewhere that you can read incase you add more, I think I used a block with attributes Any PM for offers ? A couple of often posted names here would do it easy. Quote Link to comment Share on other sites More sharing options...
