Hello,
New to autocad need some help.
I have a hard copy drawing in mm so i drew it in mm. Now i have to dimension it in inches. I have tried several things including opening a new drawing in imperial, changed the units, INSUNITS are set to 1.
Not sure what to do.
Thanks
Using AutoCAD or Inventor? Please clarify.
don't know about 2012 but you could use alternative units in your dimension style setup
I will second designerstuart's suggestion re: Alternate Units. There is a tab for it in your Dimension Style.
That will do that you for your advice
0.03937 is the conversion factor for going from metric to imperial.
can you be a bit more specific? is that inches to mm? no. inches to m? no. feet to miles? no. then what is it? i found these tables here........
inches 2.54 centimetres
inches 0.08333333 feet
inches 0.0254 metres
inches 0.00001578 miles
inches 25.4 millimetres
inches 1000 mils
inches 0.027777778 yards
feet (ft.) 30.48 centimetres
feet 0.0003048 kilometres
feet (English Imperial) 0.3048 metres
feet (US survey) 0.3048006 metres
feet (Cape) 0.3148581 metres
feet (geodetic Cape) 0.314855575 metres
feet 0.0001645 miles (naut.)
feet 0.0001894 miles (stat.)
feet 304.8 millimetres
feet 12000 mils
Edited by designerstuart
table didn't work
1" = 25.4mm; 1mm = 1/25.4 (0.0393700787)
What he said.
