I want to have a lisp creats layer with linetype, lineweight, and color myselft! Thanks a lot ! ( ex. : Layer :inter, linetype:continious, lineweight : 0.4, color : 2 )
You could easily macro this with the -layer command.
you could easily macro this with the -layer command.
i have lot layers. I lost much time for set layer. Help me pls !
If you have several layers, consider a template.
I want to have only command on lisp, and i have some layers for my new draw
MY LISP, BUT I CANT CREATS LINETYPE...
(defun c:1000()
(command "layer" "m" "NETCAT" "c" "7" "" "")
(command "layer" "m" "NETTHAY" "c" "67" "" "")
(command "layer" "m" "NETKHUAT" "c" "252" "" "")
(command "layer" "m" "NETCAT2" "c" "253" "" "")
If you can get that far, look at your options within the -layer command.
eg.
[?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]:
if you can get that far, look at your options within the -layer command.
Eg.
[?/make/set/new/rename/on/off/color/ltype/lweight/transparency/material/plot/freeze/thaw/lock/unlock/state/description/reconcile]:
i dont want modify layers. I open a new draw withou layer, i can creat a list layer for me with my set !!!
So check if the layer exists before creating it if you don't want to modify an existing layer. tblsearch or tblobjname will check.
so check if the layer exists before creating it if you don't want to modify an existing layer. Tblsearch or tblobjname will check.
my sett for all my draw, so that i dont need check the layer exists.... You can help me alanjt ??!!! Creats linetype.....! Thanks!
You want to create a linetype or apply a linetype to a layer?
Stop with all the exclamations.
yeah. tôi đã tìm thấy vấn đề này với lisp makelayer của Lee Mac. Thanks alanij đã bỏ thời gian trao đổi với tôi. cảm ơn nhiều
yeah. me have found my probl. with lisp makelayer of Lee Mac. thanks alanjt
So much for learning something. Have a good one.
i learn great things many read this site, alanjt....!??!?!!!! much patient and kindnesss, alanjt....!!!!?!?!!?
you, i thanks for laugh many!!! :P
