vnanhvu Posted May 18, 2011 Posted May 18, 2011 (edited) WHY I CANT CONVERT LISP LAYERMAKER OF LEEMAC TO VLX ! CODE : (defun c:1000 nil (vl-load-com) ;; © Lee Mac 2010 ;;----------------------------------------------------------------------------------------------;; ;; Specifications: ;; ;;----------------------------------------------------------------------------------------------;; ;; Description Data Type Remarks ;; ;;----------------------------------------------------------------------------------------------;; ;; Layer Name STRING Only standard chars allowed. ;; ;; Layer Colour INTEGER may be nil, -ve for Layer Off, Colour < 256 ;; ;; Layer Linetype STRING may be nil, If not loaded, CONTINUOUS. ;; ;; Layer Lineweight REAL may be nil, negative=Default, otherwise 0 <= x <= 2.11 ;; ;; Plot? BOOLEAN T = Plot Layer, nil otherwise ;; ;; Bit Flag INTEGER 0=None, 1=Frozen, 2=Frozen in VP, 4=Locked ;; ;; Description STRING may be nil for no description ;; ;;----------------------------------------------------------------------------------------------;; ;; Function will print list detailing any unsuccesful layers ;; ;;----------------------------------------------------------------------------------------------;; ( (lambda ( lst ) (mapcar 'print (vl-remove-if 'cdr (mapcar (function (lambda ( x ) (and (caddr x) (LM:LoadLinetype (caddr x))) (cons (car x) (apply 'MakeLayer x)) ) ) lst ) ) ) ) '( ; Name Colour Linetype Lineweight Plot? Bitflag Description ( "COT" 2 "CONTINUOUS" 0.4 T 0 nil ) ( "CUA" 151 "CONTINUOUS" 0.13 T 0 nil ) ( "CUA2" 157 "CONTINUOUS" 0.13 T 0 nil ) ( "DIEN" 30 "CONTINUOUS" 0.3 T 0 nil ) ( "DUONGDIEN" 227 "ÑIEÄN" 0.13 T 0 nil ) ( "DUONGNUOC" 38 "NÖÔÙC" 0.13 T 0 nil ) ( "DUONGRANHGIOI" 16 "NÖÔÙC" 0.13 T 0 nil ) ( "DUONGNUOC" 227 "NÖÔÙC" 0.13 T 0 nil ) ( "GACH" 69 "CONTINUOUS" 0.09 T 0 nil ) ( "GACH2" 73 "CONTINUOUS" 0.09 T 0 nil ) ( "GHICHU" 16 "CONTINUOUS" 0.13 T 0 nil ) ( "HATCH" 177 "CONTINUOUS" 0.09 T 0 nil ) ( "HTUONG" 26 "CONTINUOUS" 0.09 T 0 nil ) ( "KHONGIN" 2 "CONTINUOUS" 0.13 nil 0 nil ) ( "KICHTHUOC" 206 "CONTINUOUS" 0.09 T 0 nil ) ( "KYHIEU" 146 "CONTINUOUS" 0.13 T 0 nil ) ( "KYHIEU2" 145 "CONTINUOUS" 0.13 T 0 nil ) ( "MAI" 45 "CONTINUOUS" 0.13 T 0 nil ) ( "NETCAT" 7 "CONTINUOUS" 0.4 T 0 nil ) ( "NETCAT2" 253 "CONTINUOUS" 0.3 T 0 nil ) ( "NETKHUAT" 252 "HIDDEN" 0.09 T 0 nil ) ( "NETTHAY" 67 "CONTINUOUS" 0.18 T 0 nil ) ( "NETVIEN" 44 "CONTINUOUS" 0.3 T 0 nil ) ( "NUOC" 150 "CONTINUOUS" 0.13 T 0 nil ) ( "NUOCMUA" 53 "NUOCMUA2" 0.13 T 0 nil ) ( "NUOCTHAI" 35 "NUOCTHAI3" 0.13 T 0 nil ) ( "SOTRUC" 9 "CONTINUOUS" 0.13 T 0 nil ) ( "TBWC" 23 "CONTINUOUS" 0.13 T 0 nil ) ( "TRUC" 251 "DASHDOT" 0.09 T 0 nil ) ( "VATDUNG" 25 "CONTINUOUS" 0.09 T 0 nil ) ( "VATDUNG2" 21 "CONTINUOUS" 0.09 T 0 nil ) ( "VUWIP" 210 "." 0.09 T 0 nil ) ( "XREF" 137 "CONTINUOUS" 0.09 T 0 nil ) ) ) (princ) ) (defun MakeLayer ( name colour linetype lineweight willplot bitflag description ) ;; © Lee Mac 2010 (or (tblsearch "LAYER" name) (entmake (append (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 name) (cons 70 bitflag) (cons 290 (if willplot 1 0)) (cons 6 (if (and linetype (tblsearch "LTYPE" linetype)) linetype "CONTINUOUS" ) ) (cons 62 (if (and colour (< 0 (abs colour) 256)) colour 7)) (cons 370 (if (minusp lineweight) -3 (fix (* 100 (if (and lineweight (<= 0.0 lineweight 2.11)) lineweight 0.0) ) ) ) ) ) (if description (list (list -3 (list "AcAecLayerStandard" (cons 1000 "") (cons 1000 description)) ) ) ) ) ) ) ) ;;--------------------=={ Load Linetype }==-------------------;; ;; ;; ;; Attempts to load a specified linetype from any linetype ;; ;; definition files (.lin) found in the ACAD Support Path ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - [url]www.lee-mac.com[/url] ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; lt - name of linetype to load ;; ;;------------------------------------------------------------;; ;; Returns: T if linetype loaded successfully, else nil ;; ;;------------------------------------------------------------;; (defun LM:LoadLinetype ( lt ) (vl-load-com) ;; © Lee Mac 2010 (cond ( (tblsearch "LTYPE" lt) ) ( (progn (or acdoc (setq acdoc (vla-get-ActiveDocument (setq acapp (vlax-get-acad-object))))) (or aclts (setq aclts (vla-get-Linetypes acdoc))) (vl-some (function (lambda ( file ) (vl-catch-all-apply 'vla-load (list aclts lt file)) (and (tblsearch "LTYPE" lt)) ) ) (setq *LineTypeDefs* (cond ( *LineTypeDefs* ) ( (apply 'append (mapcar '(lambda ( directory ) (vl-directory-files directory "*.lin" 1)) (LM:str->lst (vla-get-SupportPath (vla-get-Files (vla-get-Preferences acapp))) ";" ) ) ) ) ) ) ) ) ) ) ) ;;-------------------=={ String to List }==-------------------;; ;; ;; ;; Separates a string into a list of strings using a ;; ;; specified delimiter string ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - [url]www.lee-mac.com[/url] ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; str - string to process ;; ;; del - delimiter by which to separate the string ;; ;;------------------------------------------------------------;; ;; Returns: A list of strings ;; ;;------------------------------------------------------------;; (defun LM:str->lst ( str del / pos ) ;; © Lee Mac 2010 (if (setq pos (vl-string-search del str)) (vl-remove "" (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))) (list str) ) ) ( (lambda ( lst / lts ) (setq lts (vla-get-Linetypes (vla-get-ActiveDocument (vlax-get-acad-object)))) (mapcar 'cons (mapcar 'car lst) (mapcar (function (lambda ( x ) (and (caddr x) (or (tblsearch "LTYPE" (caddr x)) (vl-catch-all-apply 'vla-load (list lts (caddr x) "acadiso.lin")) ) ) (apply 'MakeLayer x) ) ) lst ) ) ) MISS : ; error: malformed list on input ; Compilation aborted: Fatal errors found!!!!! Edited May 18, 2011 by rkmcswain added CODE tags Quote
Tharwat Posted May 18, 2011 Posted May 18, 2011 You should ask the owner of that Lisp for a permission , before you make any bit of a thing to it . Quote
rkmcswain Posted May 18, 2011 Posted May 18, 2011 WHY I CANT CONVERT LISP LAYERMAKER OF LEEMAC TO VLX ! You are missing a closing parenthesis at the end of the code. You should ask the owner of that Lisp for a permission , before you make any bit of a thing to it . I think he is OK with regard to permission. See: http://lee-mac.com/terms.html Quote
Lee Mac Posted May 18, 2011 Posted May 18, 2011 vnanhvu, Why did you copy this part: ( (lambda ( lst / lts ) (setq lts (vla-get-Linetypes (vla-get-ActiveDocument (vlax-get-acad-object)))) (mapcar 'cons (mapcar 'car lst) (mapcar (function (lambda ( x ) (and (caddr x) (or (tblsearch "LTYPE" (caddr x)) (vl-catch-all-apply 'vla-load (list lts (caddr x) "acadiso.lin")) ) ) (apply 'MakeLayer x) ) ) lst ) ) ) To the end of the code? Also, I'm curious as to why you wish to compile this code to a VLX? Quote
pBe Posted May 18, 2011 Posted May 18, 2011 vnanhvu, Also, I'm curious as to why you wish to compile this code to a VLX? Now THAT! is the question. Quote
BlackBox Posted May 18, 2011 Posted May 18, 2011 [ATTACH]27664[/ATTACH] I originally wanted to hop over to the lilly pond and post that clip, but I didn't want to presume that I had permission to do so. Separately, I've asked Mark if I might have a small user folder there, but no response (or folder). What's the big deal? No biggie... I simply suspected that your two earlier questions would evoke some interesting responses (as they have in the past). I didn't intend to derail the thread, Lee ~ Room full of boys. Quote
vnanhvu Posted May 18, 2011 Author Posted May 18, 2011 Im a new member,i failure to writing. I will fix it again later! Quote
Tharwat Posted May 18, 2011 Posted May 18, 2011 I guess the performance and the reaction is almost like that guy who's been asking for routines and has lots of accounts ! I forgot his username .but I am sure that Renderman remember that name . Quote
BlackBox Posted May 18, 2011 Posted May 18, 2011 Im a new member,i failure to writing. I will fix it again later! Hi Vnanhvu, I do hope I've not scared you off, as we are here to help. I was just being silly; I apologize. Quote
