The file autocad 2010 (dwg) that I've been working for ages doesn't open. It starts loading but then get stuk on 96%. I tried to recover it and no errors are detected.
I'm going mad. Does any one have any sugestions?
Post the drawing file. Maybe someone here will have better luck.
Hi
The file has 140mb and the attachements doesn't upload it.....grrrrrrrrrrrr
could I send it through e-mail?
140MB? Is that correct?
Could it be you have exceeded the limitations of your computer?
Yes...the upload file size for DWG files is fairly low here. I have no control over that.
I just realize that is to large even for gmail attachements
Please see my post previous to yours above.
Do you receive any "out of memory" errors?
Does AutoCAD hang or crash?
Have you tried renaming the .bak or .sv$ files and opening them?
It should work on:
processor Intel®Core™i7 CPU 920@2.67GHz
memory(ram) 6.00GB
system type 64-bit
graphics ATI Radeon HD 5700 series
140mb... no wonder you are having trouble opening it.
I tried to rename the back files but still doesn't open and also doesn't receive any out of memory errors.
Hi,
One of the main problems for me is that the objects in Auto CAD look like they are made of surface curves, and when I save this out as a DWG and import in 3DS Max it appears as though through the conversion process vertices are getting welded where they shouldnt be,
Is there a way I can take a model in Auto CAd and collapse the history so that what I am exportign is pure polyginal data, this I hope would stop any quirky welding between Auto CAD and Max.
Does it actual refuse to open or do you just get tired of waiting?
So you have solved your original problem of not being able to open the drawing in AutoCAD and are now asking for help with this second problem?
Hi,
...Is there a way I can take a model in Auto CAd and collapse the history so that what I am exportign is pure polyginal data, this I hope would stop any quirky welding between Auto CAD and Max.
See BREP and SOLIDHIST in help.
