bgon Posted May 19, 2011 Posted May 19, 2011 I most have accidentally pressed a key that messed my settings (default). before I was able to select a line or point and then type in the command, now I have to type in the command and then select the line or point (the other way around does not work). Hope that explains it in some way. Quote
Jack_O'neill Posted May 19, 2011 Posted May 19, 2011 You may have a lisp or vba program that resets that variable. If it happens again, scroll back through your history and see what tripped it. Maybe you could add a line to the program to reset it for you when it finishes. Quote
