I'm a beginner with AutoLISP, and for some reason I can't get this move command to work right. All I want to do is select everything in a crossing window from (12,0) to (0,4) and move it all 12 inches to the right.
This is what I have, but when I run the program it's only grabbing the title block and leaving everything else in place.
(command "move" "12,0" "0,4" "" "@" "@12,0" )
Do I need to use ssget or some other selection command to pick multiple entities?
Thanks in advance.
There are many ways how to do it, e.g.:
(setq wpt1 '(12 0)
     wpt2 '(0
4)
     disp
12
     ang 0
movept (mapcar '+ wpt1 (list disp 0));;you can use instead : move pt (list (+
(car wpt1 disp)(cadr wpt1)))
(command
"move" (ssget "w" wpt1 wpt2) "" "_non" wpt1 "_non" movept)
this code should work as well
(command "_select" "_w" "12,0" "0,4" "" "move" "_p" "" "@" "@12,0")
Another ...
(defun c:test (/ ss l sset)(vl-load-com)
 (if (setq ss (ssget "_w" '(12. 0. 0.) '(0. 4. 0.)))
   (repeat
     (setq l (sslength ss))
      (setq sset (ssname ss (setq l (1- l))))
      (vla-move (vlax-ename->vla-object sset)
                (vlax-3d-point 0. 0. 0.)
                (vlax-3d-point 12. 0. 0.)
Tharwat
shouldn't that be "_c" for a crossing window?
I would approach it this way:
(defun c:test ( / ss )
 (if (setq ss (ssget "_C" '(12.0 0.0) '(0.0 4.0)))
   (command "_.move" ss "" "_non" '(0. 0. 0.) "_non" '(12. 0. 0.))
Since ssget will provide a more versatile and reliable selection.
Wow, I was way off.
Thanks for the help, these worked perfectly. :D
WoW WOW if i add another way that makes 5 different ways to do a simple move does this beat the record.
(defun C:CHX ()
 (SETVAR "CMDECHO" 0)
 (setq sn (getvar "osmode"))
 (command "osnap" "near")
 (setq x 0)
 (princ "\nalters object in X direction")
 (setq ht (getstring "\n What is amount of change: "))
 (setq newht (strcat ht ",0"))
 (while (= x 0)
   (setq newobj (entsel "\nPoint to object: "))
   (if (/= newobj nil)
   (command "move" newobj "" "0,0" newht)
 (if (= newobj nil)(setq x 1))
Sorry to go off track.
