For some reason when I stretch something, if there is an object that has been grouped it will not stretch (even if it is entirely in the area). Any reason why? Any way to change that setting?
stretch as in the the one in the block editor? it would help if you upload the file..:)
If an object is entirely in the stretch crossing window/polygon, then no, it will not stretch since the Stretch command stretches the part of an object within the stretch crossing window/polygon relative to the part not inside the stretch crossing window/polygon. If an object is selected using a method other than crossing window/polygon or lies completely inside the crossing window/polygon, it will just be moved relative to the base point.
lee mac is right, only a portion of the object you want to stretch should be in the crossing window.
Check help for PICKSTYLE, and also GROUP command, selectable option. (Use ClassicGroup command for dialog.)
I guess I should clarify. I am not looking for the object I have grouped to actually stretch. I have the object entirely in the fence and it is not moving when I stretch. All other things (text, leaders, lines, etc) move if they are entirely in the fence that I am stretching.
Is it maybe a Block and not a Group?
Perhaps it is a block, and you have not got the Insertion point within the fence :unsure:
I have no problem with this, it will even stretch a single object in a group. Did you check _PICKSTYLE = 3 as suggested?
