Erase layer...
LISP2LEARN
What 'em I doing wrong here? I have several entities on the sketch layer and after sketching I want to delete that layer and all entities under it. I want to use the "laydel" command but I can't suppress the dialog box. I know that I can't delete a layer if it has entities referencing it. Can you point me out on the right direction. Thanks
(vl-load-com)
(setq MYLAYERS (vla-get-activedocument (vlax-get-acad-object)))
(vla-delete (vla-get-layers MYLAYERS) "A-Sketch")
I still find plain autolisp much more elegant and simple :
(if (setq ss (ssget "X" '((8 . "A-Sketch")))
   (command "_.ERASE" ss ""))
Have you tried this?
(vl-cmdf "-laydel" "_N" "A-BLDG" "" "_Y")
;;; replace "A-BLDG" with the layer name you want to delete
thanks David,
Yes, this erase all entities under the A-Sketch layer but still, it doesn't delete the attributes on the blocks which are on this layer and doesn't delete the layer itself. I have some blocks with attributes and the attributes are on the A-Sketch also but not the block which is on a different layer. I want to delete those attributes also under the block but not the block.
thanks David,
Now that sounds dangerous...
-David
If nothing is referencing your layer (including objects in blocks etc.), then this demonstrates how to delete the layer from the layer collection (assuming the layer exists):
(setq LayerCollection (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
     LayerItem       (vla-item LayerCollection [color=red]"YourLayerName"[/color])
(vla-delete LayerItem)
Thanks David & rkmcswain,
The answer is right in front of me. Didn't know about "_(user input)" which suppress the dialog box.
As you probably know by now, LAYDEL will delete entities on the selected layer and redefine blocks, deleting entities on that layer.
Another similar, less dangerous route would be to use LAYMRG and merge all of the unwanted layers to a new layer that you can review later. Just a thought.
Thanks Lee, very informative. I'm always impress on how you squeeze your code.
I guess, I can do that too. Here it goes..
(Setq thanks "tnx li, ur da besttttttttttttttttttttttttttttt")
(setq tnx (vl-string-right-trim "ttttttttttttttttttttttttttt " thanks))
(princ (strcat (tnx "LOL"))
Thanks for the concern, I'm fairly knowledgeable with autocad commands but not with lisp and now, I'm trying to write simple code to make my autocad life much simpler. Thanks rkmcswain, I owe you one.
Thanks for the concern, I'm fairly knowledgeable with almost all autocad commands but not with lisp and now, I'm trying to write simple code to make my autocad life much simpler. Thanks rkmcswain, I owe you one.
