Lofting/3D Extruding with Guides Problem
dulerong
Hi,
Here I have two views of my structure that I'm trying to LOFT/Extrude,
but with the guides I've drawn.
Objective:
To LOFT the circles together (or extrude them) with the polyline as a guide,
and I assume the effect of the guide would be on all sides (ie 360 degrees around the circle would exhibit the same guide effect)
Problem
For some reason I can LOFT, but I can't use the POLYLINE as a guide, like it says "it's invalid":glare:
I'm trying to make the shape of a cartoon POO (crap)...
Thanks a lot guys for your time!
@Remark:
I appreaciate your answer, but with Revolve I will get a uniform surface, which will still work in my case,
but if I wanted to create a surface that also changes in the radial direction (the revolve direction), "revolve"
wouldn't work.
@SLW210:
Thank you, but even if I choose "Path" it still wouldn't work
@nestly:
Thank you I will definitely review the limitations to see if I can work my way around.
Hoping to see some more comments if anyone has an idea!
Edited by dulerong
