dulerong
Lofting/3D Extruding with Guides Problem
dulerong
Hi,
Here I have two views of my structure that I'm trying to LOFT/Extrude,
but with the guides I've drawn.
Objective:
To LOFT the circles together (or extrude them) with the polyline as a guide,
and I assume the effect of the guide would be on all sides (ie 360 degrees around the circle would exhibit the same guide effect)
Problem
For some reason I can LOFT, but I can't use the POLYLINE as a guide, like it says "it's invalid":glare:
I'm trying to make the shape of a cartoon POO (crap)...
Thanks a lot guys for your time!
@Remark:
I appreaciate your answer, but with Revolve I will get a uniform surface, which will still work in my case,
but if I wanted to create a surface that also changes in the radial direction (the revolve direction), "revolve"
wouldn't work.
@SLW210:
Thank you, but even if I choose "Path" it still wouldn't work
@nestly:
Thank you I will definitely review the limitations to see if I can work my way around.
Hoping to see some more comments if anyone has an idea!
Edited by dulerong
Share this post
Link to post
ReMark
Do you ever watch "Comedy Central"?
I would just create a profile and revolve your crap.
Share this post
Link to post
SLW210
You do not have "GUIDES", you have "PATHS"
Share this post
Link to post
