kalai Posted June 10, 2011 Posted June 10, 2011 i have an arc and a line . by using command fillet i can do fillet .but i want outside but it fillets inside how to determine on which side in lisp. regards kalai Quote
BIGAL Posted June 12, 2011 Posted June 12, 2011 Theres a problem with fillet when doing fillet between two arc's 3rd arc it will draw a S bend osund like your problem. To get round the problem use the circle TTR command. The other way is to work out the true geometry formula rather than use fillet command. Look up surveying formulas. Quote
