when i plot using DWG TO PDF then pdf file is open.
i don`t want open the file.
how can i control using lisp..
thanks for reading..:)
You don't need lisp for that, to open PDF after printing is a setting in most PDF Printers - what PDF printer do you use?
If you don't want the PDF to open up automatically enable "Plot in background" where it says Plot Options in the Plot dialog box.
there should be an option to turn off this action in the printers preferences
On the plot dialog box select the "Pdf Plotter" and click "Properties".
Plotter configuration Editor will pop up. Under "Device and Documents Settings" tab. Click "Custom Properties".
On the "Adobe PDF Document properties" uncheck "View Adobe PDF results".
thsnks everyone :)
i made plot lisp and i want put in such as (setvar '??? 0)
??? is variable that control not open pdf files after print
can not impossible using lisp?
thsnks everyone :)
Try to create two seperate .pc3 files, one which opens the pdf the other does not, and call the appropriate pc3 through your lisp.
Or CutePDF does not open the PDF, try using that insterad of the DWG to PDF.pc3.
