Tyke Posted June 14, 2011 Posted June 14, 2011 I have created a new text object from two existing text objects and want to get the user to place the new text object interactively in the drawing with a rubber band from the original text position. Getting the rubber band is no problem, but I would like to see the text on the cursor so that the user can place the text optimally in the drawing. I've tried several things but I can't get the text to appear on screen in the placement process. Can anyone offere any advice? Quote
SEANT Posted June 14, 2011 Posted June 14, 2011 I assume this is a .NET request. If so then this thread may beinformative. http://www.cadtutor.net/forum/showthread.php?41649 The examples there are not manipulating text objects (circles,actually) but the process is the same. Quote
Tyke Posted June 15, 2011 Author Posted June 15, 2011 I assume this is a .NET request. If so then this thread may beinformative. The examples there are not manipulating text objects (circles,actually) but the process is the same. This time its VBA Sean, I'm adding a few more functions to an existing VBA program and time required to translate the whole to .NET cannot be justified at the moment. I'll have a look at Kean's example, but I don't think jigging is an option in VBA. All I'm trying to replicate is the AutoCAD MOVE command where the text sticks to the cursor and has a rubber band to its original position. Quote
SEANT Posted June 15, 2011 Posted June 15, 2011 (edited) Unfortunately VBA does not offer many options for dynamic visual feedback (referred to as “jigging” in .NET). The only option, I believe, is to make a call to ThisDrawing.SendCommand. That way the Text entity can be manipulated via AutoCAD’s own “Move” command. There are synchroniztion issues with SendCommand, though,(i.e., the commands only get called after the entire VBA code has run). If moving the entily is the final step in the process then SendCommand should work pretty well. Edited June 16, 2011 by SEANT Quote
Tyke Posted June 15, 2011 Author Posted June 15, 2011 I'm not too sure how to build the command string together. I have the text in a variable objNewText, the start position for the move in a variable varPoint1 and I want the user to pick the new position for the text (I was using ThisDrawing.Utility.GetPoint(varPoint1, "select new insertion point for the text: ") Quote
SEANT Posted June 16, 2011 Posted June 16, 2011 The GetPoint method in VBA would work well but does not allow visual feedback. This thread shows the general idea. See the post by ASMI for the string breakdown. http://www.cadtutor.net/forum/showthread.php?23468 Quote
Tyke Posted June 16, 2011 Author Posted June 16, 2011 Thanks for that Sean. We've tried it out without the 'ghost' text, that is just with the rubber band, and the guys are having no problems at all using it. So for the moment I shall leave it as it is and when I get a little time I'll add the icing to the cake and develop it a bit further. I've bookmarked your link and ASMI's code looks interesting enough to give it a go. I'm moving away from VBA to VB.NET but every now and then someone brings up a problem or change to existing VBA code and then you're right back in there. Once again thanks for your help. Quote
fixo Posted June 16, 2011 Posted June 16, 2011 What about this code snip: Option Explicit Sub dragText() Dim oEnt As AcadEntity Dim oText As AcadText Dim pickPt As Variant Dim cmd As String ThisDrawing.Utility.GetEntity oEnt, pickPt, vbCrLf & "Select text" If Not TypeOf oEnt Is AcadText Then Exit Sub End If Set oText = oEnt Dim basePt As Variant basePt = oText.InsertionPoint ' you have as well to specify base point before, 'basePt = .GetPoint(pickPt, vbCrLf & "Specify a base point : ") Dim hdl As String hdl = oEnt.handle Dim pt As String pt = "(list " & Replace(CStr(basePt(0)), ",", ".") & " " & Replace(CStr(basePt(1)), ",", ".") & Replace(CStr(basePt(2)), ",", ".") & ")" cmd = "(command " & Chr(34) & "_move" & Chr(34) & " (handent " & Chr(34) & hdl & Chr(34) & ") " & vbCr & Chr(34) & Chr(34) & pt & vbCr & "PAUSE)" & vbCr ThisDrawing.SendCommand cmd 'just a dummy message to stop command echoing: MsgBox "pokey" End Sub Quote
BlackBox Posted June 16, 2011 Posted June 16, 2011 If you do decide to go the SendCommand route, perhaps this will help: (command "._move" newss "" pt "[color=blue]drag[/color]" pause) This line was pulled from an oldie, but a goodie LISP routine (pre-Visual LISP), that Copied and Rotated a selection set (aptly named CoRo). A few lines earlier in the LISP routine, a copy in place was used, where "pt" represents a user specified base-point from which to both copy, place, and rotate the resultant selection set. I'm unable to translate the syntax for you (from LISP to VBA), or of any limitations in using SendCommand; hopefully this is of *some* use to you conceptually. If this interactive move is not at the end of your current VBA code, perhaps there exists a simple means by which your VBA can be spliced into two parts... the former, which precedes the SendCommand, and the latter, which can be called from the LISP itself? This (if feasible) would at least alleviate the need for VBA->dotNET migration... Just a thought. Cheers! Quote
