johnpieter Posted June 16, 2011 Posted June 16, 2011 I have one *.fas.I want fix the command with *lsp for that *.fas.So how to fix that command?? Here in my *.fas Command is "checking" Through Lsp i want change that Command.Just i am giving "Chk" means it should be read that *.fas (defun main (princ) ) (main) (defun c:Chk (Checking) ) Quote
ketxu Posted June 16, 2011 Posted June 16, 2011 Maybe vla-sendcommand could help you. It likes send keys method ^^ Quote
BlackBox Posted June 16, 2011 Posted June 16, 2011 Please forgive me, as I am having a hard time understanding your request. Are you asking how to decompile a .FAS so that you can modify the contained .LSP file(s)? Quote
johnpieter Posted June 16, 2011 Author Posted June 16, 2011 RenderMan.... Actually i have one *.fas for Duplicate delete.For that command is 'dupdelete'.So this command is so lengthy.So i know we cannt open that *.fas.So i want shorten that command from my lsp.Suppose if i am giving 'Test' command means its should activate that 'dupdelete' command.... Like (defun main (princ) ) (main) (defun c:Test (dupdelete) ) Quote
BlackBox Posted June 16, 2011 Posted June 16, 2011 ??? (defun c:DD () (c:DupDelete)) (defun c:DupDelete () ;; <-- Your code here ) Quote
johnpieter Posted June 16, 2011 Author Posted June 16, 2011 ??? (defun c:DD () (c:DupDelete)) (defun c:DupDelete () ;; <-- Your code here ) here your code means which code?render???*.fas Code? Quote
BlackBox Posted June 16, 2011 Posted June 16, 2011 here your code means which code?render???*.fas Code? Look, if you load your .FAS and it provides a command called DupDelete, then paste this at the command line: (defun c:DD () (c:DupDelete)) ... and hit Enter. Now test by typing DD at the command line, and hit Enter. Does it do the same as entering DupDelete+Enter? Quote
alanjt Posted June 16, 2011 Posted June 16, 2011 Look, if you load your .FAS and it provides a command called DupDelete, then paste this at the command line: (defun c:DD () (c:DupDelete)) ... and hit Enter. Now test by typing DD at the command line, and hit Enter. Does it do the same as entering DupDelete+Enter? Just tweak your acad.pgp file. Quote
BlackBox Posted June 16, 2011 Posted June 16, 2011 Just tweak your acad.pgp file. That is another option. I stuck with the LISP topic, because it sounded like they wanted to revise the source code for the .FAS, etc. Very unclear. Quote
