YZ Posted June 16, 2011 Posted June 16, 2011 We use this function constantly for A1 drawings. It is such a great feature since 2010. But I get errors with A3 and A4 plans that cut off the top and bottom or even sometimes the left and right hand sides. I have set it to ISO Full Bleed, but still I don't know how to get it to print. I am using our standard title blocks which print correctly to paper and to third party PDF creators. Does anyone know how to wrestle with this command to get it to print with bigger margins? Quote
Tiger Posted June 16, 2011 Posted June 16, 2011 In the Plot Dialogue box, go into Properties of the printer. Find the Modify Standard Paper Sizes, find the size you use and hit Modify - then you can change the margins. Quote
Pablo Ferral Posted June 16, 2011 Posted June 16, 2011 Check out this screen shot - I Hope it helps! Quote
YZ Posted June 20, 2011 Author Posted June 20, 2011 Thanks to you both. I have gone through all our standard paper sizes and adjusted them - they all work correctly now. There sure are a lot of them! Quote
emwhite Posted June 20, 2011 Posted June 20, 2011 I ran in to the same issue and I adjusted the X, Y position from within the Page Setup and that re centered it for me but it sounds like their idea was better. Quote
