namnhim Posted June 18, 2011 Posted June 18, 2011 I found this lisp that the cells that lacked height. Thanks to Uncle fix help to further column height Z (XYZ) in addition to this table. many thanks! HERE: tabcord.lsp Quote
namnhim Posted June 21, 2011 Author Posted June 21, 2011 Maybe this topic can hardly be solved at one cares! Quote
eldon Posted June 21, 2011 Posted June 21, 2011 This lisp was written by ASMI, and does not need to be repaired. If it does not do exactly as you require, then now is a good opportunity to start learning how you can alter it. Quote
namnhim Posted June 22, 2011 Author Posted June 22, 2011 recent graduates, so I do not know much about lisp, but my current job when you do other than study in school. I participate in the forum should not have the experience that my work should complete faster so it is expected that expert help! I do not have time to learn more about certain lisp but I will study when I have time. Quote
namnhim Posted June 24, 2011 Author Posted June 24, 2011 Help me with you, I was a bit less so in English to show you a little hard (like editing pictures) Drawing1.dwg Quote
ketxu Posted June 24, 2011 Posted June 24, 2011 If you can't find the reply, contact author ^^ ( i've see the same topic in cadviet, maybe yours ?) Quote
namnhim Posted June 28, 2011 Author Posted June 28, 2011 KETXU yeah! I do not know the author in the forum to communicate because I found on google. I asked a few places in the hope that someone help me! KETXU can help me edit any lisp or similar to produce a list of coordinates directly on the CAD drawings as illustrations attached. Drawing.dwg Quote
ketxu Posted June 28, 2011 Posted June 28, 2011 It will took many time to do. Please pm author in this forum (ASMI)^^, and you can use Vietnamese to talk with me, cause my E too Bad ^^: V1.3, 14th Aug 2008, Riga, Latvia ;;;; © Aleksandr Smirnov (ASMI) ;; ;; For AutoCAD 2005 - 2008 (isn't tested in a next versions) ;; Quote
namnhim Posted June 30, 2011 Author Posted June 30, 2011 mình nói tiếng anh rất tệ nhưng vì muốn tìm tòi nên phải mò mẫm thôi, mình theo rõi nhiều về KETXU rồi nên rất bái phục. tại mình có ít thời gian, vừa đi làm vừa đi học lại đang có baby nhỏ nên không có thởi gian nghiên cứu như mọi người. nhưng nhất định mình sẽ học để giống như anh em CADviet! mình cần gấp cái tương tự như mình hỏi bởi vậy mình phải tìm nhiều sân với hi vọng có để phục vụ cho công việc ngay. Quote
