tennis4you Posted June 19, 2011 Posted June 19, 2011 This is a file that I created by tracing a .PDF file. I completely detached the .PDF file. I x-ref the file into another file in model space and slap some notes on it. I then make a view port in the layout and I see everything perfectly fine. But when I print I only see the notes and not part of the x-ref file. I thought the .PDF file might have corrupted the file so I copy and pasted the lines into a new file but even then the x-ref does not print. I checked the layers, they are all set to print. Any reason this might be happening? Thanks! Quote
tennis4you Posted June 19, 2011 Author Posted June 19, 2011 X-Ref was on Def Points layer. Thanks! Quote
