MisterJingles Posted June 20, 2011 Posted June 20, 2011 Hi all On my big plots IE with loads of hatching etc I check the option to send job as BMP which as you will know saves on the memory for the plotter. My question is, can I set this up to be permanently on for every plot? Would this cause any problems? I'm simply trying to save myself time when I have to check that option. This would also help me in those instances where I forget to check it and sit for 10 minutes waiting for the plotter to fire up Thanks Rob Quote
