lineweight 0.25mm to 0.00mm
hi
We are using AUTOCADLT2010, when I open my AutoCAD drawing window showing the lineweight 0.25mm.this
One problem at time of drawing printing,every time I need to setup by default the lineweight 0.00mm from lineweight settings dialog.i tried from to setup by default from (user preference-lineweight setting) option dialog box, still this setting can not manage by default.pls any help pls
thanks& wait for ..
have you tried setting up the 0.00mm line in your default .dwt (probably acadiso.dwt) file?
The system variable LWDEFAULT holds the value of the default line weigth.
Yours has a value of 25 (widths are in hundreths of a mm). Type LWDEFAULT at the command line and enter a value of 0 (zero)
I knew somebody with a better understanding would be along to help. But 6 minutes! Couldn't you have let me have a little longer moment of glory?
OK Dave, I'll delete the post and send it again tomorrow :wink:
But in my rush to post I forgot to say that the system variable is saved in the Registry so it will apply to all new drawings.
Edited by Tyke
Update
