Recently we've had projectwise put on our machines to help with 2 or 3 jobs only.
Since then I can't use my properties box for the simplest things - even clicking on a line to see its length/layer xyz values.
Any ideas?
Edited by skipsophrenic
stupid spelling errors
properties palettes have disappeared after registry cleaners have been used. Maybe project wise did a reg clean. This problem has been discussed at lot here but I can't remember the solution. I'm sure you can have some fun searching. :)
ooooh god, if i find the solution i'll let you know
dave you are a star, it was the registry, a simple repair was all that was needed - not even a re-install :D
Info was on this thread - funnily enough it was in similar thrads below! LOL
Did you definitely tie this in to Projectwise?
