Anyone have a sample of how to do this? I've tried passing the handle string through the result buffer, then use the Database object's GetObjectId method, though that doesn't work.
Basically, I'm trying to get hold of the actual graphical object from a lisp call. Then get that object's ContextManager. Search for an attached context and pass the items in that collection back to lisp as a list.
Borrowed from Kean Walmsley
Public Shared Function GetIdFromString(ByVal strHandle As String, ByVal db As Database) As ObjectId
Dim id As ObjectId = ObjectId.Null
Dim lg As Long = System.Convert.ToInt64(strHandle.ToString, 16)
Dim hd As Handle = New Handle(lg)
''get then the ObjectId from the Handle
id = db.GetObjectId(False, hd, -1)
Return id
End Function
Thanks, that turned me onto the "correct" track. Though I've still got a problem: Now I want the DBObject from that Id. If I simply then use id.GetObject(OpenMode.ForRead) I get a fatal error in Vanilla2008.
The object I tested was a line I just drew on Layer "0", so it's not erased and not on a locked layer.
BTW, I've noticed if I simply send the ename from Lisp, this is already converted to an ObjectId. So I went with that way of doing this, but still get the exact same fatal error.
Irne`,
I've got often a similar error when I used id.GetObject(OpenMode...
Rewriting this part with using trans.GetObject(id,OpenMode... was
preventing this error in my codes, now I don't use id.GetObject at all
Can you see PM?
Sure! That works! Here's my code so far:
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(AnnoScalesExt.LispExtendedFunctions))]
namespace AnnoScalesExt
   /// <summary>
   /// Class creating functions callable from Lisp to extend its capabilities on working with
   /// annotative scales.
   /// </summary>
   public class LispExtendedFunctions
       /// <summary>
       /// Obtains a list of scales in the current drawing.
       /// </summary>
       /// <param name="args">The lisp arguments (if any). Ignored.</param>
       /// <returns>Returns a result set to lisp as a list containing data regarding each
       /// scale: ScaleName PaperUnits ModelUnits</returns>
       [LispFunction("AnnoScalesExt_GetScaleList")]
       public ResultBuffer GetScaleList(ResultBuffer args)
           Document doc = Application.DocumentManager.MdiActiveDocument;
           Database db = doc.Database;
           ResultBuffer res = new ResultBuffer();
           ObjectContextManager ocm = db.ObjectContextManager;
           if (ocm != null)
               ObjectContextCollection occ = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES");
               if (occ != null)
                   res.Add(new TypedValue((int)LispDataType.ListBegin));
                   foreach (ObjectContext oc in occ)
                       if (oc is AnnotationScale)
                           AnnotationScale asc = (AnnotationScale)oc;
                           res.Add(new TypedValue((int)LispDataType.Text, asc.Name));
                           res.Add(new TypedValue((int)LispDataType.Double, asc.PaperUnits));
                           res.Add(new TypedValue((int)LispDataType.Double, asc.DrawingUnits));
                           res.Add(new TypedValue((int)LispDataType.ListEnd));
               else
                   res.Add(new TypedValue((int)LispDataType.Nil));
           else
           return res;
       /// <summary>
       /// Get attached scales of a selected entity.
       /// </summary>
       /// <param name="args">The lisp arguments (if any). This should contain either
       /// the ename or text handle of the object.</param>
       /// <returns>A list of scale names attached to the object.</returns>
       [LispFunction("AnnoScalesExt_GetAttachedScaleList")]
       public ResultBuffer GetAttachedScaleList(ResultBuffer args)
           if ((args != null) && (args.AsArray().Length > 0))
               Array argArray = args.AsArray();
               TypedValue tv = (TypedValue)argArray.GetValue(0);
               ObjectId id = ObjectId.Null;
               Transaction tr = doc.Database.TransactionManager.StartTransaction();
               DBObject obj;
               using (tr)
                   if (tv.TypeCode == (int)LispDataType.ObjectId) //ename
                       id = (ObjectId)tv.Value;
                   else if (tv.TypeCode == (int)LispDataType.Text) //string, handle
                       long lg = System.Convert.ToInt64(tv.Value.ToString(), 16);
                       Handle hd = new Handle(lg);
                       id = db.GetObjectId(false, hd, -1);
                   obj = tr.GetObject(id, OpenMode.ForRead);
               if (obj != null)
                   res.Add(new TypedValue((int)LispDataType.Nil, null));
           else
           return res;
Now I just need to drill into how to get hold of the attached scales :unsure: ... but that's a different story! :roll:
BTW, I see you're using VB.Net. If you want to convert my C# code above, I usually use this: http://www.developerfusion.com/tools/convert/csharp-to-vb/
Thanks, I use both of them :)
Many regards
Ya da man, Irne` :)
Thanks for the help! I've been googling for this a few hours already, then finally thought OK go ask on the forum! Without you pointing me to that code, it would probably still not have worked!
