I would to know if i can write a macro to do the following steps
Save As -> under save as there is a tools tab on the RHS top.
click this to get the drop down for options
under options click the DXF Options tab i then tick the box SELECT OBJECTS
click OK
change the file type to save as autocad 2010 .DXF
user input being the name selected object i am saving
User input being select the object
If this makes sense can it be done?
Not with a straight-forward "macro". There doesn't seem to be any command-line switches for DXF version and Select objects. The only switches are for DWG version or only one for DXF (probably current latest version - i.e. 2010).
But it might be possible through Lisp, though you might have to work with ObjectDBX in such case. Haven't looked into it too deeply, maybe someone else has already done something like this.
