Hallo Friends...
I am facing a problem with text. When I am using an Arabic text , it works fine while drawing in 2D. While ploting it got morrored and got upside down...
Can some one help me, will be much the obliged. Good day:)
Arabic is read from right to left across the page isn't it? Perhaps that may be related somehow.
Have you tried it on another printer, or tried printing to PDF?
Hi..
Thanks for your response.
I tried with PDF print also. The result is the same.. Is it bcause of the
printer ?? I shall check with another printer as you said.
I don't know what causes this, but it seems to be related to Arabic True Type fonts. You may try using a shx font if you can't find another solution.
