cadplayer Posted July 15, 2011 Posted July 15, 2011 Hi, I have a polyline with line-entitys. Is it possible to smooth this polyline in line- and arc-entitys Quote
MSasu Posted July 15, 2011 Posted July 15, 2011 Did you checked the Fit and Spline options of PEDIT command? Regards, Mircea Quote
cadplayer Posted July 15, 2011 Author Posted July 15, 2011 Yes but the result of pedit is not nice. Pedit draws a curve, I would like have a polyline which draws of line and tagential arc. Roaddesign works mostly with lines and arcs. Quote
BIGAL Posted July 18, 2011 Posted July 18, 2011 You should re-read you road horizontal geometry guidelines again, the radius of curves and spirals are there so when your speeding you do not run off the road. You could though build a lisp taking into account your design paremeters and convert two straight lines joining now with the correct arc. Quote
alanjt Posted July 18, 2011 Posted July 18, 2011 Just specify the radius and pick either side of the vertex with the Fillet command. Quote
