Lisp help - delete all objects on 4 layers but exclude blocks
Need a lisp to delete all objects on 4 different layers (ZZ-UKMAP-LANDLINE,ZZ-UKMAP-RAIL,ZZ-UKMAP-STATION,ZZ-UKMAP-STATION NAME).
The only problem is that I have a block named “MAP” which I want to remain, this block has objects in it on the above layers.
So want to delete all objects on four separate layers but exclude the block “MAP” (or exclude all blocks if easier).
Can anyone help? I have been tryin to do this with ssget, but cannot write the lisp successfully,
Thanks
check this out ..
(defun c:test (/ ss i sset e)
 (if
   (setq ss (ssget "_x" '((8 . "ZZ-UKMAP-LANDLINE,ZZ-UKMAP-RAIL,ZZ-UKMAP-STATION,ZZ-UKMAP-STATION NAME"))))
   (repeat
     (setq i (sslength ss))
     (setq sset (ssname ss (setq i (1- i))))
     (setq e (entget sset))
     (if (not (eq (cdr (assoc 2 e))"MAP"))
       (entdel sset)
Tharwat
If the "MAP" block is not dynamic, this is how I would approach:
(defun c:FOO (/ ss)
 (if (setq ss (ssget "_x" '((-4 . "<NOT")
                            (2 . "MAP")
                            (-4 . "NOT>")
   (command "._erase" ss "")
   (prompt "\n** Nothing selected ** "))
 (princ))
** Untested, and written on my MacBook, I can test when I get to work **
Note - A layer check should be done, to ensure the layers are not locked first.
... Otherwise, I would step through the selection set using vlax-for, conditionally qualifying with the EffectiveName for blocks.
HTH
