flopo Posted July 18, 2011 Posted July 18, 2011 I want to measure a distance in paperspace and i select 2 ends of a line from model - distance will be that from model - is a setting for this? I want to see the dimension from paperspace, not from model ... help! Quote
RobDraw Posted July 18, 2011 Posted July 18, 2011 A quick search did not reveal anything for me other than that is normal behavior for the distance command when using OSNAPS from model space within the same viewport. In case you haven't already thought of this, you could draw a line in paperspace and get the length from that. I wouldn't just measure it where you drew it though, you might pick up the model space OSNAPS. Quote
ReMark Posted July 18, 2011 Posted July 18, 2011 As long as you are using your Osnaps the distance will be the same as though you were measuring it in model space. If you don't use Osnaps then you'll get a paper space distance. You want to have your dimensions in paper space not in model space right? If so, make sure they are associative. Quote
flopo Posted July 18, 2011 Author Posted July 18, 2011 Maybe a lisp can help... a lisp to detect the scale in paperspace and to multiply the value from model...i don't know.... Quote
ReMark Posted July 18, 2011 Posted July 18, 2011 Why don't you tell us what you are trying to accomplish. Are you doing your dimensioning in model space or in your paper space layout? Are you familiar with the terms associative and annotative? Do you know what each refers to? Quote
rkent Posted July 18, 2011 Posted July 18, 2011 change DIMASSOC to 1, use dimensions to get your PS lengths, change DIMASSOC back to 2. Quote
flopo Posted July 19, 2011 Author Posted July 19, 2011 I'm only trying to measure some distance in paperspace, not doing dimensioning and using osnap for objects drawn in Model, for exact distance - but it is impossible- so i have to draw a line between 2 points and to see lenght... Quote
SLW210 Posted July 19, 2011 Posted July 19, 2011 What is the point in measuring the paper space size of an object? Quote
rkent Posted July 19, 2011 Posted July 19, 2011 I'm only trying to measure some distance in paperspace, not doing dimensioning and using osnap for objects drawn in Model, for exact distance - but it is impossible- so i have to draw a line between 2 points and to see lenght... I realize you aren't dimensioning, but my answer gets you exact lengths, then you simply undo or erase the dims. Otherwise if you don't need exact lengths you can just eyeball it. If you need exact the other way is to draw a line as you mentioned. Quote
qball Posted July 20, 2011 Posted July 20, 2011 I thought older versions would Distance as the OP wants. I tried 2007 and no, and I don't have any older versions anymore. Quote
