SOLIDWORKS for LINUX?
Is SOLIDWORKS available for linux??
not that i know of. only 32bit and 64bit versions for windows. You will need a windows emulator to make it work. Having said that i would think the performance would be horrible running a graphical intense program on an emulator. The linux environment is great for a lot of things but i dont think graphical design software is one of those.
  • 4 months later...
do i have any alternate option for inventor in LINUX.
  • 1 month later...
Solidworks was made to run on windows. Autocad products can work with WINE emulator and some can be installed without.
  • 1 month later...
Current WINE db has AutoCAD versions 2009 thru 2012 with a garbage rating. Link
Older versions seem to work well though. I honestly don't have a problem with Linux, there are several versions that are pretty cool but I fail to see the issue with just using the OS that an application was designed to be used in.
Inventor also gets a garbage rating as well :( Link
Bricscad has a Linux version. It's more of an Autocad clone. Nothing like Solidworks. Not open source.
That FreeCAD looks promising as an Inventor alternative. I haven't used it but it does look usable.
Link
  • 1 year later...
I know
I meant that they offer versions that can run on Unix and Unix-like systems, such as FreeBSD, Linux, Solaris...
