p1nkninja Posted October 8, 2008 Posted October 8, 2008 Hello there everyone. I have been asked to draw a rectangle that is 1 wide by 3 unit tall with the bottom left corner at .75, .75 and use fillet to make the corners of the rectangle round, with the radius of .375 What i have assumed to do is the following: COMMAND: rec First point: .75,.75 other point: 1,3 Command: f r: .375 and selected left side of the rectange, and the top line Now the problem is, it wouldnt work. Thanks in advance Quote
lpseifert Posted October 8, 2008 Posted October 8, 2008 other point: @1,3 if you follow this sequence you can fillet all corners at once. Command: fillet Current settings: Mode = TRIM, Radius = 0.3750 Select first object or [undo/Polyline/Radius/Trim/Multiple]: r Specify fillet radius : .375 Select first object or [undo/Polyline/Radius/Trim/Multiple]: p Select 2D polyline: 4 lines were filleted Quote
hotrodz0321 Posted October 8, 2008 Posted October 8, 2008 because if you start at .75,.75 and end at 1,3 then your total size is only .25x2.25.....start at .75,.75, make your other point 1.75,3.75...then fillet...i tried it and it will work.... Quote
hotrodz0321 Posted October 8, 2008 Posted October 8, 2008 you can do it exactly as you did it before just make the last point 1.75,3.75 Quote
p1nkninja Posted October 8, 2008 Author Posted October 8, 2008 Cheers lpseifert, and hotrodz0321. It worked yay! For some reason, i didnt think of it that way. Cheers again. Quote
