AstroNout Posted July 22, 2011 Share Posted July 22, 2011 Hi guys, me again... I'm writing a bit of code today, because it's raining outside and I can make myself usefull like this. So, I'm trying to get a certain attribute from a block, but that in a string and plotting the string as a text in the same place as the block. Then I delete the block. Everything works just fine, except for the getting of the attributes. I've been searching on the forum, but haven't found what I was looking for, or at least, didn't understand it. Ah well this is what I have untill now: Sub BB06() Dim sText As String Dim blk As AcadBlockReference Dim ent As AcadEntity Dim p0 As Variant Dim Angle As Double Dim HNR As AcadText For Each blk In ThisDrawing.ModelSpace If blk.Name = "OCT_HNR" Then sText = blk.GetAttributes p0 = blk.InsertionPoint Angle = blk.Rotation Set HNR = ThisDrawing.Application.ActiveDocument.ModelSpace.AddText(sText, p0, 1.25) HNR.Alignment = acAlignmentMiddleCenter Dim Layer As AcadLayer Set Layer = ThisDrawing.Application.ActiveDocument.Layers.Add("HNR1") HNR.Layer = "HNR1" HNR.StyleName = "STANDARD" HNR.ScaleFactor = 1# HNR.Move HNR.TextAlignmentPoint, p0 HNR.Rotation = Angle blk.Delete End If Next For Each ent In ThisDrawing.PaperSpace If TypeOf ent Is AcadBlockReference Then Set blk = ent If blk.Name = "OCT_HNR" Then blk.Delete End If End If Next End Sub The use of the getattributes method, obviously, isn't right, but I have no idea how to use the method for extracting specific info. Thanks y'all! Arnout Quote Link to comment Share on other sites More sharing options...
dbroada Posted July 22, 2011 Share Posted July 22, 2011 try GetAttributes(0) Quote Link to comment Share on other sites More sharing options...
AstroNout Posted July 22, 2011 Author Share Posted July 22, 2011 that doesn't seem to work... Quote Link to comment Share on other sites More sharing options...
AstroNout Posted July 22, 2011 Author Share Posted July 22, 2011 (edited) Right, i've been doing some tweeking, and now it works. But it still gives an error on the last "next". No idea why, because all of my blocks are deleted and text-shizzle has taken his place. Well, well... Sub BB06() Dim sText As String Dim blk As AcadBlockReference Dim ent As AcadEntity Dim p0 As Variant Dim Angle As Double Dim HNR As AcadText On Error GoTo Errorhandling For Each blk In ThisDrawing.ModelSpace If blk.Name = "OCT_HNR" Then aAttributes = blk.GetAttributes For Each attrib In aAttributes If attrib.TagString = "ATTRIBUUT" Then p0 = blk.InsertionPoint Angle = blk.Rotation Dim PI As Double PI = 4 * Atn(1) If Angle > PI / 2 And Angle < 3 * PI / 2 Then Angle = Angle + PI End If sText = attrib.TextString Set HNR = ThisDrawing.Application.ActiveDocument.ModelSpace.AddText(sText, p0, 1.25) HNR.Alignment = acAlignmentMiddleCenter Dim Layer As AcadLayer Set Layer = ThisDrawing.Application.ActiveDocument.Layers.Add("HNR1") HNR.Layer = "HNR1" HNR.StyleName = "STANDARD" HNR.ScaleFactor = 1# HNR.Move HNR.TextAlignmentPoint, p0 HNR.Rotation = Angle End If Next attrib blk.Delete End If Next blk Exit Sub Errorhandling: Exit Sub End Sub Edit: I just tried it on an other drawing, and it stops after the second block has gone through the program. Bah! Edited July 22, 2011 by AstroNout Quote Link to comment Share on other sites More sharing options...
Joro-- Posted July 22, 2011 Share Posted July 22, 2011 It does not go through all of the Block in your drawing because some of them are just BlockReferences and there is not a corresponding block with the same name in ThisDrawing.Blocks. I made a little modification - check for the ObjectName of the entity - now it should be working Sub BB06() Dim sText As String Dim blk As AcadBlockReference Dim ent As AcadEntity Dim p0 As Variant Dim Angle As Double Dim HNR As AcadText On Error GoTo Errorhandling For Each ent In ThisDrawing.ModelSpace If ent.ObjectName = "AcDbBlockReference" Then Set blk = ent If blk.Name = "OCT_HNR" Then aAttributes = blk.GetAttributes For Each attrib In aAttributes If attrib.TagString = "ATTRIBUUT" Then p0 = blk.InsertionPoint Angle = blk.Rotation Dim PI As Double PI = 4 * Atn(1) If Angle > PI / 2 And Angle < 3 * PI / 2 Then Angle = Angle + PI End If sText = attrib.TextString Set HNR = ThisDrawing.Application.ActiveDocument.ModelSpace.AddText(sText, p0, 1.25) HNR.Alignment = acAlignmentMiddleCenter Dim Layer As AcadLayer Set Layer = ThisDrawing.Application.ActiveDocument.Layers.Add("HNR1") HNR.Layer = "HNR1" HNR.StyleName = "STANDARD" HNR.ScaleFactor = 1# HNR.Move HNR.TextAlignmentPoint, p0 HNR.Rotation = Angle End If Next attrib blk.Delete End If End If Next Exit Sub Errorhandling: Exit Sub End Sub Quote Link to comment Share on other sites More sharing options...
AstroNout Posted July 22, 2011 Author Share Posted July 22, 2011 now it doesn't seem to go through to the blocks I want to change to text. I had to add: Dim aAttributes As Variant Dim attrib As AcadAttribute So it would go through the code. Maybe I'll have to dim them differently? Quote Link to comment Share on other sites More sharing options...
AstroNout Posted July 23, 2011 Author Share Posted July 23, 2011 Right, it works, but goes through every single entity in my drawing. That's a bit time consuming. Can't I select a layer where the program should look? Thanks for the suggestions! Sub BB06() Dim sText As String Dim blk As AcadBlockReference Dim ent As AcadEntity Dim p0 As Variant Dim Angle As Double Dim HNR As AcadText Dim aAttributes As Variant Dim attrib As Variant On Error GoTo Errorhandling For Each ent In ThisDrawing.ModelSpace If ent.ObjectName = "AcDbBlockReference" Then Set blk = ent If blk.Name = "OCT_HNR" Then aAttributes = blk.GetAttributes For Each attrib In aAttributes If attrib.TagString = "ATTRIBUUT" Then p0 = blk.InsertionPoint Angle = blk.Rotation Dim PI As Double PI = 4 * Atn(1) If Angle > PI / 2 And Angle < 3 * PI / 2 Then Angle = Angle + PI End If sText = attrib.TextString Set HNR = ThisDrawing.Application.ActiveDocument.ModelSpace.AddText(sText, p0, 1.25) HNR.Alignment = acAlignmentMiddleCenter Dim Layer As AcadLayer Set Layer = ThisDrawing.Application.ActiveDocument.Layers.Add("HNR1") HNR.Layer = "HNR1" HNR.StyleName = "STANDARD" HNR.ScaleFactor = 1# HNR.Move HNR.TextAlignmentPoint, p0 HNR.Rotation = Angle End If Next attrib blk.Delete End If End If Next Exit Sub Errorhandling: Exit Sub End Sub Quote Link to comment Share on other sites More sharing options...
dbroada Posted July 23, 2011 Share Posted July 23, 2011 you can create a selection set for just blocks or just blocks on a certain layer. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 26, 2011 Share Posted July 26, 2011 sText = blk.GetAttributes Stext(0) is first attribute sText(1) is netxt and so on You can use filters to search for a block name Dim FilterDXFCode(0) As Integer Dim FilterDXFVal(0) As Variant FilterDXFCode(0) = 0 FilterDXFVal(0) = "INSERT" 'FilterDXFCode(1) = 2 'FilterDXFVal(1) = "SCHEDTEXT" Set SS = ThisDrawing.SelectionSets.Add("pit1sel") SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal attribs(0).TextString = attrib string value try filter code 8 for layer Quote Link to comment Share on other sites More sharing options...
dbroada Posted July 26, 2011 Share Posted July 26, 2011 Thanks BIGAL, I'm not at work this week so could only suggest what to do, its nice to see the code. Quote Link to comment Share on other sites More sharing options...
19cruthik68 Posted September 27, 2011 Share Posted September 27, 2011 follow up question. Where do you usually put that text? I dont know how to use that thing?can u give me an info. thanks Quote Link to comment Share on other sites More sharing options...
