If I have 100 pline , how can i add segments to any pline by a specific distane
is there is any lisp can help me please
Aren't you really just lengthening each pline rather than adding a segment of a predetermined length?
Does it matter if the pline is horizontal or vertical or at an angle?
Does it matter in which direction the pline is lengthened?
Just to make sure of what you want to do. The distance to be from the start of the polyline? Or a distance along one of its vertexes? Also does the polyline contain arcs?
This may get you halfway there, but if you want to specify a distance, you might need to do a little calculation with the length of the selected objects :wink:
