Hi,
I'm looking to make a dynamic block that will either strech up or down but some of the element stay the same in the other visivility
Here is a block i am talking about!
dynamic block.dwg
I believe I was working on the same thing a little while ago. See if this block answers any questions.
SHORING.dwg
Well i can't see what you did because the autocad drawing is written protected. What ill be doing with this dynamic block will be stretching from the top but also the bottom. but i want things to fallow since i have more then one block in this one
It should be backwards compatible from 2011 to 2010. I didn't protect the drawing in anyway. Did you try opening directly from here or saving to your computer first?
