Change colour of ByLayer by selecting entity in drawing
Those issues generally only exist when trying to entmod certain properties of newer type entities (MLeader, etc.) or any annotative object, but color/layer/linetype are not of that list.
As long as entities' colors being ByLayer it would have nil DXF 62 , that's what I experienced at least .
  • Replies 27
  • Lee Mac
    8
  • woodman78
    5
  • Tharwat
    5
  • alanjt
    4
Posted Images
This is not an issue. Consider the following programs to change all primary entities to green. You can either test for the occurrence of the DXF 62 group code, altering it or appending it:
(defun c:alltogreen ( / el en ss )
   (if (setq ss (ssget "_X"))
       (while (setq en (ssname ss 0))
           (setq el (entget en))
           (entmod
               (if (assoc 62 el)
                   (subst (cons 62 3) (assoc 62 el) el)
                   (append el '((62 . 3)))
           (ssdel en ss)
Or, this could be simplified to:
(defun c:alltogreen ( / en ss )
           (entmod (list (cons -1 en) '(62 . 3)))
           (ssdel en ss)
I did not mean changing entity' color to a specific color but getting an entity's Color when its being ByLayer the DXF 62 would be equal to nil
If the return is nil, then get it from the layer's entity dump.
(defun color (ename)
 ((lambda (entityData)
    (cdr (cond ((assoc 62 entityData))
               ((assoc 62 (tblsearch "LAYER" (cdr (assoc 8 entityData)))))
   (entget ename)
1+
I'd add the abs too:
(defun color ( ename )
   (lambda ( entityData )
     (abs
       (cdr
         (cond
           ( (assoc 62 entityData))
           ( (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 entityData)))))
   (entget ename)
     (abs
       (cdr
         (cond
   (entget ename)
Good point wasn't thinking about off layers, of course, it's kind of difficult to select objects on a layer that's turned off. LoL
