hetauma Posted July 28, 2011 Posted July 28, 2011 Hi I have some blocks with lines and some attributes. I want to be able to rotate the block freely but I want to always have the rotation of the attributes at 0 deg. Is there any way to lock the value of the attributes rotation to 0? Quote
irneb Posted July 28, 2011 Posted July 28, 2011 Annotative Text style? There's an option to "Match text orientation to layout". If you don't want to use Annotative, then you'll need a lisp to modify the attributes after the rotate. Quote
qball Posted July 28, 2011 Posted July 28, 2011 can you do Parametrics? put a Rotation Parameter on the block and exclude the attribute. Quote
irneb Posted July 29, 2011 Posted July 29, 2011 Or even the other way round, though I think I remember you need to lock the attribute to have it work with parameters. Quote
