blackeagle1245 Posted July 28, 2011 Posted July 28, 2011 My display configuration is in plan view. But I have one or two parts that I want to see them in another view. For example schematic. I'm changing object display making it override but still their views dont change. What should I do?. Quote
tzframpton Posted July 28, 2011 Posted July 28, 2011 What do you mean by "another view"? You might have to create another Display Configuration depending on what you're after for the end result. Quote
blackeagle1245 Posted July 29, 2011 Author Posted July 29, 2011 no I mean I want my drawings in plan view but I want one mvpart in schematic view . Quote
tzframpton Posted July 29, 2011 Posted July 29, 2011 Display Manager, Sets, , select Multi-View Part, uncheck the Plan Representation and check the Schematic Representation. Link to full res image: http://dl.dropbox.com/u/4989089/Images/DM_Schem.jpg Quote
blackeagle1245 Posted July 30, 2011 Author Posted July 30, 2011 but it is a general solution I know this. But I want only one type of mvpart for example linear diffuser to see in schematic view. Quote
tzframpton Posted August 1, 2011 Posted August 1, 2011 Oh, just a single object. Now this will change all references of the MvPart, not just the one MvPart. But it's probably what you're looking for. Do this: Right-click the object, select "Edit MvPart Style" and click on the Views tab. Under "View Name" scroll down until you see "Two Line - Top" and select it. Then under the "View Block" drop down, select the schematic version of the MvPart you're using. Most, if not all, of the default MvParts have a 2D schematic version of the block that you can override. Quote
blackeagle1245 Posted September 16, 2011 Author Posted September 16, 2011 I have activated both plan and schematic view I want to change mvparts display as I wish for example cav in schematic view, grills in plan view. But when I change mvparts properties nothing changes it just stays the same. Quote
blackeagle1245 Posted October 19, 2011 Author Posted October 19, 2011 still waiting for a solution:?? Quote
